OldSkool
Hypothetical question here.
I don't yet have a Vette, but I'm considering getting a C3. I don't know a heck of alot about them, so I'm trying to do some research. I know alot of them were relatively underpowered, and since I don't believe in slow Vettes (or stock 350's!), I'd definitely be modding it. While not as fast as I'd ultimately like to go, I think that running in the 13's is respectable, and not too crazy a goal.
Say I had a '75 or '76 L-82 with a 4-speed. What would I need to do to get it to break into the 13's in the 1/4? Now I know these engines only came with about 200hp, but if I'm not mistaken, the L-82 has a 4-bolt block, higher compression, and better heads (2.02) than the L-48. Please correct me if I'm wrong, btw.
Assuming the engine is in good shape with reasonable miles, would I be able to accomplish this w/out getting into the internals? I'm thinking headers with a free flow exhaust w/high flow (or no) cats, GM Vortec heads with matching intake, and a good carb might do it, with the right tuning. I'm not sure what gears these came with, so a gear swap might be needed too, but nothing too low, as I'll need to drive this on the highway.
Does this sound feasible? Or will I need to do a cam swap also? If so, does the engine need to come out to do that?
And how much power can the stock driveline take? I'd imagine plenty, since they installed big blocks in these cars. A 13 second small block is probably barely scratching the surface.
Thanks for any info. Like I said, I'm a Vette novice, so any help or suggestions are greatly appreciated.
Mike
Mike
