Buckskin7T7V
Where else can the hot engine air get into the car ventilation ducts? I have a 77 with A/C. I have replaced the hood weather stripping. Hot engine heat is getting into the ducting somewhere and when I turn on any setting: Vent, Heat, Def. A/C , MAX. I get hot air. The temp control lever is in the cold position. The A/C compressor went out and it is not belted up. I understand the outside air comes in on the passenger side, in the windshield cowling behind the protective plastic screen. I can see the blower fins. Somehow hot air from the motor is getting sucked into this ducting and blows into the car. The heater hose are blocked.
ad
