Pseudomind
Here is the issue, if you have ever seen one they are a nightmare compared to the standard GM C5 bra
They have six openings on the front four of these openings, the two screens and the turn signal lights have eight tabs which are to be inserted each time you install the bra between the top/bottom edges of the lights and screens. Believe me this is a real pain.
Now my question, just what function do the screened vents serve on the Z06? I know they probably allow more air, but in normal everyday driving is this necessary?
The standard C5 bra does not have tabs or openings, clear plastic instead an will come off/on in just a couple of minutes.
I only want to use one, a bra for road trips and not everyday use, so if I purchase a standard C5 bra, should I maybe expect heating problems?
