damoroso
Okay, looking for opinions out there.....
I've got a nice clean 81, that's currently stock. I'll be adding true dual exhaust in the next month or so. It used to be that when you went from stock exhaust manifolds to headers, there was a good hp boost (making sure you completed the job with the rest of the exhaust system). My 81 has factory "header" style manifolds on it now. Is there really a gain to be had in changing those to a set of the "hugger" style of header? My guess is to get the most benifit, I should go with long tubes (using koolmat under the carpet). Thoughts?
And now for the big one. I've really wanted to swap an LS2 into the car, possibly stroking it, changing the cam, heads and intake looking for about 450 - 500 hp. I plan on using a 700r4 trans (I'll at least do the dual exhasut and put the trans in the car before the swap so I can still drive it while gathering the rest of the parts) or possibly a 2004r. The rear gearing may have to change down the road.
The big question is, should I spend the money on the LS2 (assuming I build it from a short block up) or put the money into a traditional small block? So far, I think I'm looking at around 6-7K to do the engine work and swap (I can do all the work). I've not tried to get that kind of hp out of a small block before, I'm looking at stroking it, bringing the compresion up to about 9.5:1 (does anyone know if the 81 block is a 4 bolt?), the right cam, having the heads worked, (flow, matching ports, vavles, three angle cut, all the normal stuff) or changing them all together, matching the intake,(maybe fuel injection) and carb. I'm looking for drivability (including decent fuel mileage, with the LS and trans I'm expecting 25-30) and to smoke those annoying little metric cars that sound like model airplanes, and of course to BBQ Mustangs....
