MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
Well, my plans for the Shark have gone through a number of evolutions, as I'm sure many of you have noticed. Happily, I've avoided the temptation to buy expensive parts that I then don't end up needing.
I had envisioned the Shark as a nicely-performing daily driver, which kept conflicting with the old "more power" impulse. But with a Buick GN to play with, I'm now thinking that I might as well consider that my "driver" and go a little more radical with the Shark. Lose some of the practicality and up the fun factor a bit
That opens up a few things. One being that if I have an automatic-transmission car (the Buick) for a daily driver, I can give serious thought to converting the Shark over to stick shift. Another being that more aggressive rear gear ratios become possible, since gas mileage ceases to be as much of a concern.
Something that I've been thinking about is eventually installing an LSx engine of some flavor. With the likelyhood of a large displacement LSx derivative becoming available in the next few years for the new Z06, that becomes even more of an intriguing possibility. It also leads me to think seriously about keeping an eye out for a 6.0L truck (iron block) LSx engine if I can get a good deal on one. If I make the necessary adaptations to install that engine, I can get some fun out of a modern engine with larger displacement, and then when I can afford a fancy aluminum critter, I'll already have the appropriate mounting hardware and such installed, so the installation would pretty much be a matter of dropping in the new engine and attaching its computer.
I'd like to come up with a well-thought-out plan of attack, and I'm just curious if anyone has any thoughts on this...
Joe
Joe
