Whiplash
I got my frame back this past weekend from the stripper. It came out great. They sprayed it with DP90 Epoxy primer inside and out and it really looks good. On the way home I stopped at a local body shop to see if they could squirt it with paint to finish it off.
Here's the question. The shop wanted $700 to paint the frame. The frame is fresh clean primer but they said there was 10-12 hours of sanding required before they could paint it. I asked if the sanding was to give it a nice finish or if it was required for proper adhesion. They said the paint wouldn't stick to the primer unless it was sanded.
OK, I can believe that the primer needs to be sanded. It didn't come immediately to mind but it does make some sense. My question is whether it's actually true or not. If so, how much sanding is required to get the paint to stick correctly? What grit paper and how do you know when you've sanded enough. Once it's sanded is spray paint a sound enough finish.
Alternative 2 - Leave it alone and don't paint it. The finish looks great in just the primer. It's the right color and has a really nice coverage. Can I just leave it as is and put the car back together? The negative is that it's not UV protected but how much UV is the frame actually exposed to? How long will it look good if I just leave it alone?
Maybe Paintdaddy can chime in or anyone else who has used DP90. I had already ruled out powder coating due to the lack of coverage inside the frame. It's too late to powder coat now that it's primed.
Thanks in advance. I'll post pictures once I free up some space on my web page. I'm maxed out right now.
Whiplash
Whiplash
