Gotta take the tank outta my car
  • Thread starter Thread starter Dave1966
D
Dave1966
i have to remove feul tank 4 flushing and cleaning
wots the quickest way to get it out
do i have to remove bak bar?
how do i get t\lights out?
do i have to accsess everything from under the car?
i may aswell clean everything while im at it !
how do i get injectors out do i have to remove intake tubes to get feul rails clear enough to get inj. out?
feul pumps stuffed ,tank doesent look that good, worst case wots a complete s/hand tank sender pump unit go 4 in the states?
thanx Dave!!!!!!!!!!!
If you MUST remove the tank;
1) remove the filler tank door and romove the 9 screws holding the filler neck housing. Disconnect the feed and return lines and the electrical.
2) Behind the license plate there are two (I think) bolts holding the "fascia" in place.
3) remove the spare tire carrier and exhaust from the cat back.
Now you can reach all the braces and tank straps for removal. You will need help dropping the tank once you have everything unbolted.
You will also be able to reach all of your rear lights at this point.
I just did my fuel pump and it was about $180 CDN.
thanks mate but i got the feul tank out already,
bout to remove injectors
there are 2 tork head bolts holding feul rail to the intake manifold
if i take these 2 bolts out will i get the feul rail hi enough to remove injectors or will i have to remove air tubes and air plenum to get them out?
thanks
dave
