Help! Grounded diagnostic connector
JOHNNYB
BIDDEFORD,ME
1989 DARK MET. BLUE COUPE
HI, I AM ADJUSTING MIN IDLE AND TPS AND IN THE PROCESS IT SAYS TO GROUND DIAGNOSTIC CONNECTOR THEN TURN KEY TO ON POSITION AND WAIT 30 SEC. BEFORE DISCONNECTING AIC TO SET MIN IDLE BUT WHEN I GROUND TERMINAL A+B AT TOP RIGHT OF CONNECTOR THEN TURN KEY TO ON POSITION THE RADIATOR FAN COMES ON. I WAS JUST WONDERING IF THAT IS NORMAL ;shrug:W
THANK YOU FOR ANY REPLIES
Correct ,
when in "diagnostic " mode which you are by grounding the ALDL the ECM runs the fan :thumb
