OK --I AM SORRY I LEFT OUT THE "L"---IE SPLICE PACK---IT IS A NUMBER OF GROUNDS IN PARTS OF THE SYSTEM THAT COME TOGETHER IN A PACK ---AND C4C5 IS THE "MAN"
I CAN TELL YOU NOW HOW TO FIND THE ONE THAT TAKES CARE OF ALL!! THE BACK END LIGHTS ---TAIL,STOP,BACKUP,DIRECTIONAL AND HAZARD----ALL YOU GOTTA DO IS TAKE OUT THE INSIDE RIGHT SIDE TAIL LIGHT LENS AND IT IS TAPED TO THE WIRING HARNESS JUST INSIDE TO THE LEFT OF THE TAIL LIGHT HOLE-----MY HAD TWO OF THE "FEMALE" TERMINALS THAT WERE NOT CONTACTING THE MALE PLUGS AND "VIOLA"
THERE WAS LIGHT !!!!!!
BUT TO HELP OTHERWISE I DID NEED TO REPLACE MY HAZARD SWITCH TOO. IT WAS BAD--AND TAKING DOWN THE PANEL UNDER THE STEERING COLUMN HELPED A LOT 'CAUSE I COULD GET MY RIGHT HAND TO THE SWITCH FROM UNDER ----BUT PULLING THE CONSOLE IS ALSO GOOD AND NECESSARY--ALSO INSTALLED ONE OF THE "CORVETTE ENHANCEMENT" TURN SIGNAL BYPASS AT SAME TIME
NOW!! EVERYTHING WORKS!!!!
THANKS TO PAT AND PAUL
