J
jorez
Just got a new 1974 vette, how do I tell if it has the Gymkana susp?
The actual spring is 2.5" wide and has 8 leafs in it for the 1981 year model. I talked with the Chevrolet Tech. Dept., and they told me that the very short leaf-like at the top is not considered a part of the spring as far as function is concerned. So when you count the leafs your count should come to nine minus the one that is not counted which leaves eight leafs. As a matter of fact, you'll find that if you order the Restoration Package from Chevrolet for the 1981 vette it shows on page 21 of the specification booklet at the very bottom has a note describing the FE7 Gymkana spring as an 8-leaf spring. I believe that the the 7-leaf spring was around in older corvettes. The rear stabilizer bar was unique to the FE7 suspension at the rear. As a matter of fact, the FE7 suspension also included "special" shock absorbers, but I have not been able to find the part number for them.
