Hammerhead 12 Bolt Center Section
yedister
New member
Dallas, Texas
1986 Silver
Having my Hammerhead 12 Bolt Center Section installed in my 1986 Corvette Dana 36. I got it from the Street Shop in Athens, AL . It can handle 1000 horsepower with no problem, It requires a Dana 44 Batwing. It's being done at Heisler Automotive in Hamilton, New Jersey is doing install.
Street Shop Inc. Offering Custom Built Replacement Chassis For Your Corvette | Home
You have to call and speak to Tray, it’s not listed on the website
HammerHead 12 Bolt based Aluminum Differential Housing
C4 Corvette Flange Pattern
5.5 Wide Pattern Mount with Four 0.56 Thru Hole; 2.527” Bearing OD, 2.570” Seal OD; Bright Silver Nitro –Plated In/Out
Build HammerHead 12 Bolt Rear Differential Assembly to Include:
New Eaton 30 Spline Positraction Unit
3.73:1 Gear. Bearing kit, Seals, and Pinion Yoke
Billet Chromoly Axle Stub for 10.7W HammerHead 30 Spline Long Side to 1350 Flange
1350 U-joint Flange, 4 Bolt for 10.7 Hammerhead
Billet Pinion Spacer for C4 Torque Arm
