I would like your thoughts on improving a base suspension '84. According to the chart on this forum this in the only C4 with a higher rear spring rate than front (approximately 365 vs 415). I don't want to spend a lot of money - the car needs other work. I would like to stay under $500.00. I really don't want to change springs either if I can help it. I was thinking a 30MM Z51 front sway bar and a "good" set of shocks ($300.00 or less if possible). Koni's are out the budget - but what about the other choises - Monroe - KYB - Delco - TPIS - Mid-America - even Bilstein? What about the rear - should I go to a bigger rear sway bar also - or is it not needed due to the high spring rate? Well what do you guys think? Thanks in advance for any and all advise. Jack
