S
steve84
Got the vette out saturday rebuilt the throttle bodies,new plugs,It still takes a long time for it to start.any Ideas?Is there any way to check the coil?or maybe the voltage going to the plugs?
During cranking the oil pressure switch will bypass the relay and directly energize the FP, but it still should run for a couple of seconds after turning ignition on but before starting. If its not doing this then it is not building up pressure before you start cranking, only after it has started cranking. This can cause longer than normal start-up time. Might also be a good idea to stick a FP gauge on there and see what the pressure looks like. When you turn the key on (before cranking) the gauge should jump up to somewhere between 9 and 13 PSI pretty quickly, and it should maintain that pressure while running.steve84 said:have not check to hear the pump but I had the aircleaner off and I can see the injectors spraying while It`s cranking.I`m thinking I`m not getting enough juice to the plugs like maybe the coil is going bad.
