mcditalia
It all started with the thermostat housing needing replacement!
It all snowballed from there, found out radiator is shot, so while I'm at it pulling everyhing out it's a great time to change the pulleys to correct setup. Now I realize that my harmonic balancer is the 6" base 300hpmotor kind that is pressed into the crankshaft.? I knew when I bought my car it consisted of many different year parts slapped together. My block is supposedly the original L79. I say supposedly because it has the HT stamp with with my vin number on the engine pad. I took the engine pad paint off years ago and showed horizontal broach marks which looked convincingly factory.
So my point is will the 6" balancer work on this motor? If its pressed into the crankshaft, will the bolt on 8" finned correct one fit too? And how do I make the swap? I'm assuming that the correct double grove/belt pulley setup will not fit into my 6" balancer? With many years into digging into this car with limited mechanical abilities this is new territory for me.
