SSTibet
Folks,
I know this is a minor defect but I want my Corvette as perfect as possible...
Problem is at the "air intake plenum for a/c & heater" area at the base of the windshield wipers. My "cowl top hood to plenum seal" has deformation around where the left and right metal grills are mounted on it. As you may already know the seal is made of rubber and is attached to the firewall with a number of screws / small bolts. There are two metal grills (driver & passanger sides) that are screwed to this rubber seal. I also notice something like a chemical putty (compound) between the seal and grills. I also notice sort of air holes (irregular shape holes) on the surface of what I call the "putty".
The "cowl top hood to plenum seal" looks in pretty good shape except for the grill interface areas, where it has "bowed away" from the grills. There are gaps almost 5 - 6 milimeters (little less than 1/4" or so) wide between the seal & grills.
I have been thinking of replacing the seal but I am now afraid of this since I have noticed this putty stuff around the grills where the current problem is. Has anyone changed this seal / grills before, and what is the luck for success? Should I do this and if yes, how?
I have attached picture of the parts from Corvettecentral and from my car below.
Cheers,
Selim
Cheers,
Selim
