head removal
billd
Denver,CO
2001 red convertible, 1985 wht
Hi everyone,
I have an 84 and am trying to remove one of the heads. I have removed all the bolts and boy is that sucker stuck. Anyone have any suggestions (ie tricks) to remove this guy.
Bill
BigRed
Edmonton
1985 Bright Red Rocket
2x4 Block and a good Peen Hammer!
Thin wall gasket scraper or pry bar (Don't damage the head or block)
Spray some nut cracker AKA WD40 and let it soak
Those are my Ideas Good Luck
B
Bullitt
Good advice, but when I get frustrated, I bring out a 10lb. sledge. It runs the wood block, but what the hell. If you're really careful, you can use the exhaust ports to pry upwards on the head. Just don't use something too abrasive. A hammer handle or something should do the trick.
--Bullitt
grumpyvette
Loxahatchee, FL, Palm Beach co
first make sure you have ..ALL THE HEAD BOLTS REMOVED..theres 8 in the bottom row 5 in the second row and 4 in the top row (total 17) if you did not remove 17 from each side youll break the head trying to pry it off. lots of people forget the two end ones in the middle row because they are set down in the oil return areas
BigRed
Edmonton
OOOOHhhhhh Wouldn't that suck! I can just imagine building up my car after years of saving and forgeting to remove a HEAD BOLT
Aww Id Cry for sure
billd
Denver,CO
got it off
Finally I got it off. Oops missed some bolts. Now I'm looking at it and I can see that three of the exhaust valves are a nice light grey color and one is dark brown. I'm thinking this isn't good. Is it? When I look at the valve and the seat neither one looks bad on the seating surface. There is no carbon where it would have leaked any ideas?
BigRed
Edmonton
Is it rust? from a possible head gasket leak?
Is the Valve chipped or warped allowing fire into head?
Is the Valve seal leaking?
If it was me and I had to heads off Id just change them out (Like why not hard works done already) and make sure the machining on the head itself after removing the valves are in good order. Its USUALLY a good Idea to have a machine shop REseat them if your installing new valve.
One more thing on the cylinder where the burnt valve was, is the some piston slap on the clyn walls of the block? Allowing a little bit of oil to pass through.
Could be a million things but knock them off one at a time by checking the block and the head out.
Good Luck
