Here's a pic of Hedman Hedders on my former '81, which also has a ZZ4 and passed emissions w/o problems. The ZZ4 has no exhaust crossovers in the heads for the EGR, but the EGR was left attached for the visual inspection (They don't test it to see if it's working - just has to be there). Anyway, there's also the heat riser issue. Thorley has some available, and I think Holley has them as well, but you won't find any that you can directly adapt to 3" header flanges without reducers. I think the largest riser I could find was 2.5". Decided just to forgo the heat riser. They never noticed (or looked). They will, however look for the the more obvious, and that's the EGR, the A.I.R. pump, diverter valve, exhaust manifold air tubes, cat., etc. The Hedmans fit perfectly. No having to 'ding for clearance'. They ran very close to the tranny, and I wrapped the two cooling lines with reflective heat wrap tape. I had the front Y made up at a muffler shop to retain the 2-1-2 stock style exhaust system. Oh, and how's about that performance improvement over the stock shorty headers? Not much that I could tell. Probably more worthwhile in the upper rpm range. I bought mine from Jet-Hot. They were right at $500 with the coating. They did a great job though.
Just wanted to add that if you go with ceramic coated headers, the heat will be so reduced that you may have problems with your 02 sensor. I had Jet-hot weld an 02 bung on the driver's side collector before they coated them. I ended up having to replace the 02 sensor with a 3-wire heated version.
