I
igasper10
Hey all,
I finally diagnosed my RH headlamp problem. The whole assembly sits about 1/2" below where it should be. Comparing it to the LH side, which is in good shape, I found that the bracket that bolts to the wheel well is broke in half! This is NOT the actual headlamp assembly bracket. Its the bracket that that attaches to. Make sense? How should I fix this? If this bracket is not easy to replace, I'll probably end up bonding the top of the headlamp bracket to the bottom of that edge of the front clip just forward of the hood. Any suggestions???
ian
ian
