Help! headlamp assy. adjustment
procketus
Hickory, NC
1980 all Black
Finally got around to installing a repair kit for the headlight vacuum last night. Now they both WANT to go up, BUT. When they start to raise the back edge of the assy. on both sides hit the edge of the header panel(guess that's what it's called). What I want to know is if there is an adjustment I can make to bring the whole assy. forward about an 1/8" or so forward? Also the assy. is not sitting flush with the rest of the header panel, so they both need to be raised up.
Both sides would work fine if they did not hit. All it takes is a slight lift with a finger to get them up.
