T
tcarollo
I am looking for the dimmer switch rod that runs from the dimmer lever on the column that you flick down to the headlamp dimmer switch that is located on the bottom left side of the column under the dash. This setup was unique to the '77's I believe. I'd consider purchasing the whole column if necessary and knew everything was there, but really I just need that rod.
