Headlamp warning light intermittent on problem
  • Thread starter Thread starter ernie d
E
ernie d
Hi guys
On my 69, the center console headlamp warning light intermiuttently comes on and off, whether the lights are up/on or down/off. The lights work fine, but the warning light comes on regardless.
Anybody have this before? Loose wire or short? Suggestions for best path to track it down?
Thanks guys and gals
Ernie
There is a plastic switch mounted by the headlight each door. They tell you the lights are on but the bucket isn't up. Remove the light bezel and look for a loose or broken switch.
Roll up under the car and look through the round/oval cutouts and you can see the switches also mounted on the linkage.
Eddie,
Thanks for the pictures.......perfect. :beer
Ernie
