bigwheels
New member
My Driver side headlight does not become flush with the rest of the hood when closed, you can jiggle it with your finger. sometimes the motor works and sometimes it gets stuck in the middle of its cycle both when turning it off and on. If you roll it up manually you can feel the gear slip at the end of each cycle causing it not to be flush. I have replaced the gear with no success, as well as the headlight actuator module. Its just a big headache, any solutions are welcome with open arms. Im considering just taking it to a specialist and letting them deal with it. Any recommendations near the New Bern NC area?
otfl
