Headlight bump stops, where can I get them
I give up! What are the symptoms you guys see when the stops are bad and need replaced?
Andy Anderson :w
Bump stops
If and when you need to replace the nylon gears in the headlight door, at the same time just replace the bump stops, 1 symptom is the headlight door goes down and then goes back up. These bump stops are made of rubber or something like that. they just wear out after time.
When I changed out the plastic gears with the brass gears, I saw that the bump stops were worn on just one side. All I did was slide them off and reversed them, good as new after that.
