Headlight Control Module
skitch
liberty sc
'90 Artic White Convertible
I'm having problems with the headlight doors on the left hand side of my 90 convertible. It won't open or close . According to the service manual I need to replace the module. It has power going to the headlight motor when the headlights are turned off. The module is $170 thru my local dealership. My question is this, Is this a common item to go bad? It's a expensive piece to replace and that not be the problem. I replaced the bushings a few months ago and they were working great until now. ;shrug
Problems with motors are usually more common.Does power go full time to to RH motor as well ?
On the early style lights there is a limit switch in the motor that shuts off power ; this gives problems.
Not familiar with the solid state switching you have.
The right headlight works as it should. I replace the left motor recently also with the smae results. I bought a module off ebay for $50, I'll let you know how that comes out. Thanks
Skitch
