C
CharlesBrown
Got everything off tne hood and am now down to the gear motor. Got the 3- screw cover off the gear motor too. Problem... The thread I was following said to remove the wormwheel. Mine refuses to come out. The wheel turns freely nothing seems to be stuck, but when I try to get the shaft & wheel assembly free of the gear housing it won't come out. Looking at the instructions I was using, there is a boss at the back of the gear housing where I assume the output shaft rides and it appears to be open such that the shaft could be driven out Wheel and all. Mine however has the shaftbearing-housing integral with the gear/motor housing. No access to the rear of the housing. Any thoughts on how to get the worm&wheel out would be much appreciated.
