Headlight Motor keeps trying
GuyzVette
Wichita, KS
Polo Green 1994 LT-1
94 LT1 Coupe.
When I turn off my headlights, the passenger side motor keeps trying to close the headlight, even if it's closed already. It clicks several times for about 10-15 seconds and then stops. Is there an adjustment or something that is not telling it that it's closed, or anything else I can check?
Thanks,
Guy
The bushings in the drive gears need to be replaced. They are cheap but the repair is a little time consuming. Do a search here for this and you should find several threads discussing this issue and how to effect the repair.
