headlight motor problems
  • Thread starter Thread starter keith hodge
K
keith hodge
i cleaned and lubed my headlight motors but they still work slow-one only works in one direction-i have had them apart a few times to try to figure out-they spin very freely-dosnt seem to be rocket science --brushes are good-all solders look good--gears all are good--armature looks good-help
keith:confused ;help
Not sure I can help much, but:
1. Have you tried spinning each motor's serrated wheel by hand with the motor and headlight assembly in place to see how much resistance there is then to it turning? (should turn quite freely, just takes forever to see any appreciable movement of the headlight housing) I haven't repaired any, but I understand there are large round pivot bearings/balls supporting the headlight housing that can corrode and cause binding, as could any misalignment of the attaching parts, etc. Do the headlight assemblies rotate freely with the motors removed?
2. Have you checked the harness voltage getting to the motor, and the resistance of the ground connections, to see if wiring connections are clean and getting the full voltage?
3. When you say the motors spin freely out of the car... have you applied 12v to them on the bench to see if they spin up, or are you simply spinning them by hand?
4. Is there a way you could borrow a known correctly-working motor to try it in your car?
Breaks in the windings, or breakdown of the insulating (shellac?) coating on the windings, can cause DC motors to lose power. I don't have a shop manual with me to see if it gives any test specs... it may require a professional motor repair shop to determine whether there are internal shorts or other problems.
i have cleaned and lubed the pivot balls-the lights turn by hand with ease-
the motors spin easy by hand with the thumb wheel
i havent checked actual voltage at the motors-i can do that
grounds are good and clean
i will check voltage -if thats ok i guess i will have to send them out
they seem so basic.
keith
Keith,
If you need to send the motors out for service/restoration my highest recommendation is for:
Restoration Service
Steve Hackel
15000 S. Knox Ave
Midlothian, IL 60445
708-687-4183
He did mine and I have nothing but praise for his work and turn around.
Don
