Thanks for the links, hadn't thought about those bumpers. Went out and fiddled with it this morning but no luck. What I neglected to mention is that the new gear I installed was plastic just like the old one. Figured it's brand new, only $12, had to work at least once, right? WRONG! Bottom line: quit being so cheap, buy the good parts and avoid the unnecessary headaches. So I ordered the metal gear replacement this morning. There are still some of us out there that need to be slapped twice before stuff sinks in, I guess I'm one of 'em. The up-side is I'm getting pretty good with these headlight motors.
Can't imagine what else it might be. This gear makes the same offending sound as the old one(at least the old one stopped when it was supposed to, maybe I should put it back in). I guess I'll just wait to install the metal gear.
Does anyone know how to stop the headlight motor from running after the headlight closes. I replaced the worn gear in the motor, did I miss some other adjustment procedure?
Thanks DK
