tred95
Was having shut down problems. Car would stop dead at about 200 degrees and wouldn't start again until the temp dropped back to 180-190.
Had a lot of aftermarket stuff on the car, fan switches, Delteq so I decided to take everything back to stock.
Replaced the opti and water pump and car runs great with one issue that is driving me nuts.
The car will start almost instantaneously in the morning with hardly any cranking. It will also start (no matter what the temp is) immediately after I have shut it down...like stopping for fuel.
The issue comes after it sits for several hours. It will crank for an extended period without starting. I'll stop cranking, turn off the key and back on and crank it again and it starts immediately.
Its almost like the starter is spinning the engine too fast for the Opti to sync the signal to the ECM.
Any help would be appreciated.
thanks,
Pete
thanks,
Pete
