Sixty_vette
I finally had the opportunity to pull the heater core on my 1960 Vette and take it to get pressure tested and repaired. I was thinking it was the core that was leaking, but the pressure test revealed it was the heater control valve. Anyone know if the rubber gasket/diaphragm/washer or whatever is inside can be replaced - OR - does the entire control valve need to be replaced. Have not had any luck finding just the parts to "fix" mine. I would like to keep as much of the original parts as possible!
Thanks!
Thanks!
