R
RoyalViking
Oh boy,
The front and rear intake manifold seals had swelled (silicone) and the engine was leaking quite a bit of oil. I had planned to pull the car into the garage to put the new intake gaskets on. However, I was suspicious of a coolant leak. The previous owner had used stop leak at some point in time. I pressure tested the system at less than 20 lbs psi and noticed the pressure dropped quickly. I left the pressure tester on and started the engine to see if it was a head gasket. I discovered the leak as the engine warmed up. I had steam coming out of the heater/def vents. The car stalled and would not start for a while.
After I removed the pressure tester I tried to start the car and it would not run. I got it to run for a minute and then fire once more while trying to start it.
My guess is the leaking heater core has gotten the ecu damp. I left it sit thinking it might start the next day. I noticed the check engine light does not light up when I put the ignition to the on position (prior to trying to start). I removed the trim panel under the heater core and it had antifreeze all over it.
How difficult is it to remove the heater core?
Is my ecu toast?
Roy
1989 C4
Is my ecu toast?
Roy
1989 C4
