I currently have my dash apart, I've been debating as to whether or not I should replace the heater core. I know that it hasn't been replace for at least the past 4 years...and have no idea if its the original in there. What should I do?
been here recently pal......the vacuum line to the right needs to come off......there are 2 screws that are hard to see but they are under the plastic that the heater flows from......keep removing screws and put them in a bag and label it....and like your doing take pics for refrence. there is a cable that attaches to the arm on top of the box......comes off also......im thinking the problem you have is the bolts are in the engine compartment that let it drop into the car.there is a door that controls the heat direction.....this was a main source for a rattle in mine....i used a couple of rubber "O" rings to help take up the slack....no rattles and the heater works real good. by the way.... i got my new core at murrays auto parts for $29.....and i have a/c.......best price by about $30 over books and other stores.good luck....let me know.chastonyk72 said:I now go the pass. seat out, so I got more room to work. I flipped through the AIM and a Chiltons, no details oh how to get it done. I tried removing what I think is the heater box (what I outlined in yellow) and it doesn't want to seem to come loose. Any tricks to this? BTW, my car has AC, I hear it's different for non AC cars...
mine isnt a name brand that i know of....didnt see a brand name come to think of it.....just take your time....you will need to attach the hoses to the core assy before you put it back in the car...good lucktonyk72 said:What brand should I go with? Are there any I should stay away from? I was looking to get an AC Delco. Today, I went to an AC Delco parts supplier in my area. They told me that AC Delco never made the cores, they were actually made by Harrison (for AC Delco). They also said that they would be unable to get this part. All the so called "correct" cores in various parts catalogs appear to be AC Delcos.
Are the repros just as good? There seems to be about a $30 price defference between trhe Delcos and repros. I'd rather pay the $$$ up front and not have to worry about it.
Also, should I be replacing anything else while I'm at this? Hoses, gaskets, etc?
