HEI Guide On-line?
EricVonHa
Suburbia Phila
'93 6-Speed & '87 Callaway
Hi everyone... I'm looking for a guide to HEI troubleshooting on-line.
So far I've replace the ignition module. The coil checks out ok. And, I've replaced the four pin external module also from a known running Vette.
Any ideas of where to find good HEI info? I've done a search and just haven't hit payday yet! :)
http://chevythunder.com/fuel%20injection%20troubleshooting%20page%20C.htm
http://www.babcox.com/editorial/us/us80312.htm
http://www.hotrodders.com/t32774.html
http://retro.co.za/efi/DIY_EFI/1996/efi1-174.txt
Thanks CC. The first link was great. #2 and #3 were previously found through Google. And #4 is a dud.
The problem (as I see it) is that the ECM is not seeing the reference signal being fed back upon a "crank" situation because the ECM is not firing the injectors.
I get a good solid 12vdc to the coil also.
