Hi Crebo,
Many people discredit the flex-fan with really doing anything to cool down an engine...but for us...it was the ONLY thing that cured our run hot problems.
We lived in California, a central farming valley north of Sacramento with summertime temps of up to (and usually over 100 degrees).  When summertime rolled around I was forced to slow down.  I could not drive the 70mph limit on the fwy.  Wintertime was fine, but if the temps went up, so did my water temps.
We replaced fan clutches, water pumps, belts, hoses, radiator, fan shroud, tuned the engine...everything we could think of and nothing worked.  After 5 years of battling this run-hot-summer problem, we replaced the engine with a GM crate engine and repaired the non-operable AC.
The engine still ran hot if I traveled fast, but if I used the AC it shot up to 240 in a hot minute!  We moved to Washington state, and I did not use the AC at all for 3 years.  Running temps would get a little warm driving up the grade in the summer, and if I kept my speed down, the water temp stayed down.  This was now 3 years after the new engine.
We moved to Georgia and the first summer here, it would still run hot if I drove fast.  Kenny and I bought a flex fan (the only thing we changed) and immediately it fixed our run hot problems.
I can drive at any speed, at any time of the year AND use my AC in town or on the hwy!  We also made a drive to Helen (mountain roads) with 3 other vettes ('77, '88 & '96) and Kenny drove the 78 like we had never driven her before... rpm's at about 2500-3500, peaking at 4500 for almost 20 miles of uphill curves and switchbacks and she never even came close to 200!
We have now had the flex fan on the 78 for about 1.5 years and have never overheated.  The fan is louder than the fan clutch, but not in a whiney sort of way, I think it sounds nice.  I like hearing it, and knowing my radiator and engine compartment are getting plenty of air.  The one we purchased (at a speed shop, $40) is a light blue with silver colored blades, metal.
Previous temps: (hot summer temps)
195-200 degrees at 55mph
210-225 degrees at 65mph
240 with AC at any speed  *I never tried to see how much higher it'd go
winter - I could drive 70mph and temps would stay below 195
After flex-fan: (hot summer temps, AC & cool winter temps)
never over 195
Good luck with your big block, and I hope my information helps you.  It worked for us.
Heidi
