hzl6cm
I pulled the radiator off of the '58 283 V8 yesterday to replace the old damaged fiberglass fan and I noticed that there is no harmonic balancer on this engine - should there be one? It looks as if the crank shaft has a flanged piece on it and the pulley is bolted directly to it. The engine is no longer in a Corvette but is in a '66 MGBGT that I purchased last year. I don't have the engine nuber handy but it is an early one that has front motor mounts and no side ones - if I recall the date code correctly it is an early 1958 engine. I also understand that the engine may have been stroked and bored back in the early '70s when it was installed in this car. Thanks!
Kevin
Kevin
