S
Skant
Please... I know this is a very long description of the history of this problem... but particularly if you know corvette drive trains, I hope you'll read this.
I'm feeling stuck. I need help. At this point, I'm so frustrated that I'm starting to become tempted to sell my previously beloved vette.
Okay... here's what's been happening.
I had 4.11 gears (Tom's Gears) installed in the car along with a number of other mods. The shop that did it guaranteed me that they would be quiet (I've heard 4.11's are prone to whine if not installed juuust right).
Got the car back after the mods. The shop warned me that they were concerned about the transmission. It was noisy. And they didn't like the metal content in the transmission fluid they had replaced.
Followed the breakin instructions to the letter. The car produces a warbling whine sound cruising on the freeway starting about 65mph. Mostly present between 65-80mph. Loudest at 70-75mph. Letting off the throttle stops the sound. Giving it more throttle lessens or stops the sound. Pushing in the clutch stops the sound. The sound has a sort of omnipresence. The sound seems to come from the rear, but it is most audible near the shifter.
I took it back to the shop that did the mods. They did a road test with me and decided that, because the sound went away when the clutch was pushed in and because of the metal they had found in the transmission fluid, it was not the rear end. They say they spent a lot of extra time setting up that rear end, and it must be perfect. The transmission needs to be rebuilt.
I am not so certain. I take it to a transmission specialty shop and another corvette specialty shop for other opinions. For both of them, on explaining the problem over the phone, they thought it would be the new 4.11 gears. And for both of them, when they actually road tested the car (the tranny shop actually put it up on a lift and used a stethoscope, too), they agreed with the first shop that the noise was from the transmission.
The first shop also claims that the car made these sounds before their modifications. And two of my friends say so as well, though they think they may have become louder. I think if it was as loud as this, I would have noticed. But the sound may have been present (quiet) before.
Okay. Well, everyone seems to be in agreement that it's the transmission. So I have the first shop rebuild the transmission. Two months pass while they have it because they broke a specialized tool and had to wait for a replacement. Then, when they're finally supposed to be done, they call me and tell me I'd better come look at this.
The car is on the lift with its transmission and driveline removed. They tell me to rotate the flywheel back and forth by hand. It moves freely. It shouldn't be able to move like that. That's bad. They say they've never seen such a damaged flywheel and clutch. It gets worse... they show me in the partially disassembled transmission where there's a lot of metal shards in it. One of the dogs is missing a tooth. The shafts and certain gears are losing their hardness and need to be replaced. And they're not even all the way into it yet... already the cost of replacing the damaged hard parts is prohibitive. The transmission is too damaged all over to be worth rebuilding.
The idea here is that, for whatever reason, the springs in the dual mass flywheel have broken. So each shift is slamming hard against the drive train. This has done a lot of harm to transmission. Probably before I ever owned this car.
The shop bails me out by installing another ZF6... out of a 1992 (earlier style, straight cut gears)... for the same cost as I would have for rebuilding the one. Using the owners personal backup transmission for his car. But the flywheel and clutch must also be replaced. A single mass flywheel setup is actually _much_ cheaper than the stock dual mass, and it's more performant so I go for that option. So all this costs about $6500 and takes another week or so.
I get the car back... the transmission sounds different. Several noises have been deleted. The single mass flywheel makes it's rock grinding noises (they don't both me). However... the annoying warbling whine it made on the freeway remains exactly as it was. Not changed at all. Maybe a little quieter... maaaybe. But it's been more than two months since I last drove this car.
I take it back to them. They're surprised it's making the same sound. They still believe it's the transmission. I'm skeptical, but they tell me they're so certain of it that they're going to replace the transmission with a third transmission out of a 94 for free.
In a large way, I can't fault this shop. As expensive as it has been for me, they've been taking losses to do this stuff. An entire tranny swap for free is not a small sacrifice on their part. So I have to believe they are sincere!
Unfortunately, when I brought the car in for this, they said that the tranny appeared to actually be out of a 90 or 91. It was sold to them as a used 94. It has the older style shifter with the lockout, so it couldn't be a 94. They're doing the swap anyway.
When they're done, the warbling whine sound still persists.
They say they don't want to install a fourth transmission in this car. 'It must just be the nature of the beast'. So they've ended up calling it normal and letting it go.
So here I am. I can not believe that this is a normal sound. I drove two other C4's... including another LT4 like mine... they made a lot of the same sounds mine does... they made the sounds that don't bother me... but they didn't make this annoying warbling whine sound at all.
I have had three different ZF6 transmissions in my car. And I can say that each of them have had related but different characterstic sounds to them. Different personalities. Just by listening to them, I could tell you which tranmission was which. _However_, the warbling whine sound has remained exactly the same in each case. So I have a doubly hard time believing that all three transmissions are producing this exact same sound when all the other sounds they make differ somewhat.
I don't know what to do really. Maybe the obvious thing is that it's the 4.11's. My original thought. But if my friends are right, and it was making such a sound previously and it just got louder with the 4.11's... well... I don't know. The vette makes a lot of various noises, so I think that may be confusing.
My research on the forums shows a possible match for the wheel bearings or the u-joints. I have noticed, with the car on a lift, that I could rock the rear wheels in the 12 and 6 o'clock maybe 1/16th or 1/8th of an inch. The fronts do not have any such movement at all. The shop says they've checked my wheel bearings and they're fine.
I guess maybe what I need is a shop which really specializes in corvette drivelines that's somewhere near San Jose, CA to take it to. Or... just someone to turn to. Some super expert I could show the car to and they could say "Oh yeah, that's the u-joint on the left side."
The shop where I had all this done is supposed to be one of the best corvette specialty shops around. And, as much as they've failed to fix my problem, I think that they still are. They sure tried, and then some. I've just been in very bad luck. Plus, they did show me the old transmission and fly wheel and all... they were quite damaged, so the money I've spent so far is maybe not in vain.
I think the problem may be elsewhere in the driveline. Possibly also caused by the flywheel. If the jarring forces wrecked the previous transmission... they may have also done damage elsewhere. However, the shop said the rear end looked good when they put the 4.11's in. And they applied a rebuild kit to it as well while they were at it for the various wear parts (they recommended I do this since it wouldn't be much more expense and it would already be open).
Anyway... I'm just feeling pretty bad about all this. I've spent so much money on it, and the irritating noise persists. It makes me not want to drive my vette anymore. The noise is annoying in the first place, but becomes extra annoying with the emotional baggage attached. I'm so frustrated!
Any advice? Help? Please? If I can't resolve this somehow, I'll probably end up selling this car. It's my first taste of vette, and I liked it before. But maybe it's all just too expensive and problem prone for me.
- Skant
- Skant
