hzl6cm
I need some help, I was going to install my xm radio in my '04 Z06 but I can't find the aux radio connector location (this is the connector that a CD changer would have hooked in to - I know that you couldn't get the CD changer on the Z06 but the connector should still be there). I bought a PIE converter to hook to the conector (so that I can run the XM signal directly to the radio through the aux harness rather than over the FM converter) but I can't find the connector to plug it in to. I understand from other post that it is in the passenger side foot well, but when I pull the cover there I find a fuse box, the computer box and several wires and connectors but nothing that I can identify as the radio aux connector. If somebody could point me in the right directon I would appreciate it!
Kevin
Kevin
