S
sothpaw
My car's in the mechanical shop now, but just before it went in, I borrowed a co-worker's
buffer and 3M microfinish solution.
This guy talks a good talk, says he builds his own street rods and such, paint and mechanical.
So, anyway, I go to work with him to buff it, since he's the expert. Instead, he says he
has to go, here's the stuff, shows me how to use it, and (opps) squirts some microfinish
onto the hood. But when I try to remove with a towel, it doesn't want to come off. Normal,
he says, buff it out.
So I go drive the car home, I make sure the hood is cool in temperature, and buff in the
shade. This tool only goes to 1200 rpm max, which he says is good, "the only way to
hurt the paint is to burn it". So I follow his instructions, I don't push down, just let the
weight of the buffer push down and take off the microfinish. (I also made sure to clean
the pad first).
So anyway, when finished, under garage light, it is apparant that there are tiny scatches
in the local areas where I buffed it. ESPECIALLY where the blobs of microfinish started out.
Asked him at work, he says no way, can't be scratched, buff it again.
I've lost faith in this fellow. I'm tempted to take it to a good body shop and ask them
to try and buff out what I did. What do you all think? The only good thing about all this
is that it's only 2 localites on the hood, not the whole car, and not very apparent in sunlight.
But, I can see it in sunlight if I look at a the right angle, it is not my imagination.
the pad first).
