BLACK MOON
Well I'm going to start a new post because this problem has gotten worse. This started after rebuilding my 327/300 hp motor. I removed and cleaned all electrical connections before reinstalling the motor. Now setting the timing to a good running condition has been impossible. Well I broke down and took it to a reliable shop and low and behold the motor has the wrong timing cover and welded tab on it. The guy puts in heavier springs and corrects the timing. The car runs ok for about 10 minutes and then starts hesitating, pulsing, spitting thru the pipes and what sounds like backfirring. The sidepipes makes this racket sound like gunfire and the pedestrians don't seem to care for it. This occurs at a steady speed or decelerating. Acceleration is strong and no popping. I've changed coil, and installed hotter plugs at his suggestion but neither helped. I'm using an MSD tach drive dist. and a 6A box. Does the box need to be grounded? Could I have missed a ground when I detailed the engine compartment? We're all scratching our heads and butts trying to figure this one out. Any help would be appreciated. We are pretty confident it's electrical but that about I know. And we could be wrong.:crazy
