S
studiog
Posted this in the C3 forum but since it is relative to all small blocks I thought I'd post it here too. The C1 - C2 forum is where I live and I know there are allot of knowledgeable people here also.
I understand if it gets moved.
Working on my brother in laws' 71. Recent rebuild. Motor has a miss. I have isolated it to the #3 cylinder but can't figure out what is causing it. I pulled one wire at a time from the distributor as it was running and #3 made no difference in motor rpm.
Here is what I've checked so far:
1.) replaced spark plug
2.) replaced plug wire
3.) Compression 145-155 in all 8 cylinders
4.) Cam lift on #3 intake & exhaust is normal
Any comments welcome.
Thanks all.
Thanks all.
