M
mdsbch
I just got my 85 a month ago and I'm trying to find the timing mark and plate that has the degrees above and below TDC. After looking at a Chiltons manual, I've looked all around the crankshaft balancer assembly and can't seem to find the plate or the mark on the balancer assembly. Is it possible that someone could have removed the plate with the degrees above and below TDC marked on it? :confused
