Help! Fix for rear spoiler / wing
silver98
southeast PA
1998 Sebring Silver Coupe
Hi folks,
A friend has a C-4 with the rear deck lid wing / spoiler. The bolts that hold the wing onto the deck are a bit loose. He was able to tighten the rearward bolt by accessing it through a hole on the top of the inside taillight recess. The forward bolt is casauing a bit of a problem. He removed the plate around the gas cap, but said the tank was right there and was unable to get to the forward bolt. Any ideas?
Thanks,
Joe
N
nyernga
silver98 said:
Hi folks,
Thanks,
Joe
Try removing the license plate and back up light assembly
silver98
southeast PA
He mentioned that was the way to get to the taillight bulbs for replacement, but wasn't sure he could get a socket up there. I'll give him your suggestion.
Thanks:w
JonM
East Haven, CT- USA
84 Coupe
He could try using a gear wrench...or removing the taillight lens. for that you need a long extension, a swivel, and a #10 socket.
silver98
southeast PA
Hey Jon,
Great idea! We talked about that at the Auto-X, but he was clueless on how to remove the taillight lens :ugh
I told him he needs to get the service manual, but $$$ may be a concern. With out being a pest, could you provide directions on how to remove the taillight lens? A cursory glance by me didn't reveal any torx bolts on the lens.
Sorry for all the questions, but I am C4 stupid. Maybe I should change my logon screen name to that. :L
JonM
East Haven, CT- USA
84 Coupe
First off, its not a piece of cake. What you need for tools is a rachet, about a foot and a half of extension, and a #10 swivel...preferably one of these.
...but a plain swivel with a socket will work.
Look at the turning light on the passenger side under the front hood. You will see the type of bulb connector that is used on the rear tail/stop lights. Practice how it is removed with that one. Notice you have to squeeze the tabs and turn it to remove the connector/bulb-socket. Now get a friend with long skinny arms and have him reach up from under the car and remove the two inner connector/bulb-sockets. Now get your tools mentioned above and slip the socket over one of the three bolts holding the lens in. Do the same to the other two bolts and the lens pops out the back. It will be fustrating, but it can be done. Good luck
silver98
southeast PA
Much great thanks everyone! You are all the best!! I'll give him the info tonight, and the CAC web address. He needs to be here asking his own questions.
You guys are really terrific, thanks again,
Joe
And just so you can't say you didn't get one from a C5, well here it is: :w
