M
Mart
Help, lost a nut.:ugh :cry
I was puting the strut back on the body bracket and I felt the nut slip a bit then poof, it was gone.
Straight into the hole in the frame right behind the body bracket, Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
W
ad :W
How the hell am I going to get this nut back, my only thought is using a magnet, one question, is the frame aluminum or steel, if aluminum I can use a magnet from the outside to drag it up.
If this does not work I could take off both struts and the body bracket so i will have room to work.
Any suggestions.
Mart
Any suggestions.
Mart
