Help, need Part #'s Opti & water pump seals
W
Whitecoupe
:confused Well after 74K miles and 15 years water pump finally gave up so am replacing that along with dreaded opti. I am looking for distributor shaft seal part # along with water pump shaft seal part #. Also where to purchase same. Anything else I need to perform this major surgery? Thanks for any imput on this subject. Also can these seals be installed from the front of timing cover, or does timing cover have to come off as well?
LT4man
Chicago
96 Collectors Edition LT4
Call Chris at Superior Chevrolet!
1-800-728-8267
Tell him Greg from Chicago told you about him! He will give you a great price. The seals are all available separately. You can replace them without removing the cover, but it would probably be easier with taking the cover off.
SAVE THE :w
Notorious
Confederate States of America
Highly modified '95 A4 coupe
Pick up a Felpro front cover set and even if you don't use the gasket, it's still cheaper than buying individual seals. Top quality, no worries there. Autozone even carries Felpro and some other retailers do too. Should only be around $20 or so.
