T
		TooTall
New Generator - Still Problems!!
11/4/04
Hope someone can lead me in the right direction here.
Replaced the Alternator about 30 days ago when I was having problems with charging. Three times over the last 30 days for no apparent reason I get a "Charge System Fault" on the DIC with codes of:
P1637 H Generator L-Terminal Fault
P1637 H C Generator F-Terminal Fault
With a drop in voltage as if no supply coming from the alternator.
This is intermittent as again for no apparent reason the problem then resolves itself.
11/5/04
OK, It is a remanufactured from Duralast (AutoZone). Went in this morning and they traded out for a new unit that tested good on the Duralast tester. Got it on and still no voltage from the alternator. Still haven’t checked any wiring except both engine grounds, battery leads and a visual check of the alternator wiring.
I understand that the voltage from the alternator is controlled by the PCM. Could it be that I have a faulty PCM?
I'm at a loss as to what to do now.
I have removed and cleaned both engine compartment grounds. I'm a diy kinda owner, but I don't know where to go next.
			11/4/04
11/5/04
