Bob Wurtak
I bought my 95 4 years ago and its been a "Blast", but I'd like to get some info on 3 RPO codes. I don't have the build sheets or the window sticker. There's also some odd ball things with tires and rims which don't match the RPO codes that are on the door and inside the rear storage compartment.
I believe the tires are original to yhe car as the car has 26000 miles on it and the tires are Goodyear Eagle GS-C's and they look like tires with that much wear.
The rear tires are correct size at P285/40 ZR17's and that's what the RPO states. The front tires are P275/40 ZR17's and the RPO code states P255/45 ZR17's causing the car to be hard to steer in rutty roads which is all we got in Canada.
The rims are 95 ZR1 rims or look alikes but are Frt 17 X8.5 and rear 17X 9.5
painted 5 spoke aluminum.
The car has option J55 which is the heavy duty brakes 13" up front and 12'" in the rear and RPO G44 rear axle 3.07 ratio and RPO G92 Rear Axle Performance Ratio and FE1 which the soft ride suspension system.
It almost looks like there were putting together a Z07 package piece meal.
The RPO codes in question are:
R6Z which states control sales item 25
R7K which states special option processing
1SB which states market option package 2
Anyone got any ideas as to what these codes are and whether these ZR1 rims were a factory option?
