Ok, I'm confused. Haven't used a timing light or set timing since I sold my 85 Dodge 13 years ago, and the procedure seems more complex on the Vette.
1. The VECI sticker says to disconnect the ESC wire, which it claims is a tan-with-black-stripes wire and NOT to disconnect the 4-wire connector at the distributor. My Haynes says to look for the wire near the brake booster and disconnect it there. I cannot find a tan-with-black wire, just a tan one that comes out of the distributor at a port marked "TACH" and disappears between the block and the firewall. This is a single wire going to the distributor; is this what I disconnect? Nothing vaguely likely-looking near the brake booster. Service manual doesn't seem to be any help. I disconnect this and the tach doesn't work... makes sense given the label.
2. Found the timing guide, with small teeth and one large tooth, and a hole by the large tooth. Could NOT for the life of me find the timing line on the pulley or nearby, but there WAS a series of holes in the (technical term) flywheel-looking thingy that the crank pulley attaches to. When I flash a timing gun down there, the holes are 'sitting' at the bottom of the timing scale. Is the hole a replacement for the normal mark, and my engine is woefully out of time? Or is the mark just obscured by dirt/rust/age? Are the holes supposed to line up?
Thanks in 'advance'...
[RICHR]
[RICHR]
