Help, where's the fuse
HPG
Bel Air Md.
99 FRC MN6
Just notice that none of the three switches for the rear hatch work. Hopefully, it’s a fuse. The book says it’s in the dash behing the driver info center , is that where it is located Also, where is the relay located.
All of your fuses should be located on the extreme right of the dashboard, hidden when the door is closed. It should be clearly marked "fuse panel" or something like that. The hatch fuse will be label as such I believe.
The owners book says it's located behind the driver info center. THe VATS fuse and relay are back there. It maybe the relay if I can find it.
Before I tried to squeeze in back, I tried the latch first, it worked this time. I removed the cover and found two relays back there plus the cable release. Checked all of the connections and they seemed OK. I'll leave the release wire stick out and see what happens
