Help with Part Numbers
  • Thread starter Thread starter chris1
C
chris1
I just purchased a 1991 Convertible, and am ready to give it a tune up; can you guys help with out with the full GM part numbers on the following items, since I probably will be placing an order with GM Parts Direct. I'm not sure if there is a part number resource section on this forum:
Spark Plugs (standard and AC Delco Rapidfire)
Ignitions Wires
Distributor Cap
Rotor
Ignition Module inside the base of the distributor
Gas Filter
PCV Valve
Air Filter
Oxygen Sensor
Coolant Temperature Sensor
Thanks in advance, Chris.
