Help with removing a C1 tach..
J60FI
Ontario, Canada
1960 Red on Red
Can anybody give me any direction on what the best way to remove the tach would be..
It is currently installed in the dash..
Thanks..
cbernhardt
Lexington, NC
62 Conversion Car, Pewter 98, 59 Project
The tach has to be removed from the rear of the instrument pod so you will need to remove the pod to get to it. Are you asking for information on removing the pod?
Charles
J60FI
Ontario, Canada
1960 Red on Red
Charles
Guess there is no way to remove it without taking the pod out.
How do i remove the pod easily?;shrug
cbernhardt
Lexington, NC
I won't say that there is absolutely no way to remove the tach without removing the pod, but I tried it once and gave up in frustration. There is no easy way to remove the pod either. I have also tried just removing the mounting bolts and tipping the pod enough to get to the tach, but overall I would say that it is easier to just disconnect everything and pull the whole thing out where you can get to it. Dropping the steering column helps also.
Charles
J60FI
Ontario, Canada
1960 Red on Red
Charles
Thanks I will give it a try..
